CINEMA Connection Kit. question. | SatelliteGuys.US
budda
596
100
Oconomowoc
Is the kit built in on the HR44? Using the On demand feature, say for Prime time shows. Or seeing a episode of "Hell on Wheels" That was missed. Is there a extra cost? I was told that old Receivers you needed tp purchase the kit for like $75. But the new receivers have the kit built it. Just checking. Thanks
Sounds like a have to make a call I have a install rescheduled. They were going to include The kit for free , then she said since I would be getting a HR44, I would not need it because it is internal? Thanks for the reply.
No need to reschedule. All work orders are flagged with broad band connection. If you get a 44 then the tech will connect the internal, if you get a 34 then he will install either a wifi deca or a broadband deca.
swm satillite aiming
Portable setup for fish house
