Ciel 2 @ 129 LNB Question | SatelliteGuys.US
PopcornNMore
3,635
128
Gibsonia, PA
I am posting this here, because FTA guys will probably know the answer to this question rather then in the Dish Network area.
I have a Dish 500 with 4 Dish Pro LNB's (110, 118, 119 and 129) going to a DPP44 switch. My 129 (HD) from Ciel 2 has a signal strength of only 15 and comes and goes. Rather than getting on the roof and adjusting the Dish 500 dish I adjusted my Primstar (Channel Master) dish having a standard LNB (circular) at 129 and the signal strength is now in the 80's where it should be using an FTA receiver.
Question:
Will I be able to attach a coax from the standard circular LNB into the DPP44 switch or does this switch require a Dish Pro LNB to be used? I want to try it, but thought I would ask before any possible DPP44 or VIP722 receiver damage occurs.
Question:
You cannot mix DishPro and Legacy LNBs with switches. (when using DishNetwork receivers)
Won't cause any harm, but neither will it work.
All you need, is to put a recycled dishPro (bandstacked) LNB on the Primestar, and you are good to go.
Bolts right onto the existing feedhorn.
See picture: Primestar feedhorn with DishPro LNB (Dish feedhorn removed).
Is this a good deal from Sadoun?
RTN on amc 3
