Chicago=Dish 1000?? | SatelliteGuys.US
Chicago=Dish 1000??
shanks909
58
Wheeling, IL
I have a dish for 61.5 and a dish500 for 110/119. It's all legacy equipment, with a SW64 serving a 921, a 501, and a 508 receiver.
My question is: When I call in April for the $299-200 upgrade, will Dish replace my existing set-up with a Dish1000?? Will this include the switches needed to serve all my receivers??
The reason I ask is because last year I called for the "free" 61.5 dish, so I could receive several local Chicago channels not on 110, and Dish charged me $99 for the SW64 (at the time I had only the 921 & 501)
Will I be charged for an expensive switch again, or does the offer really include everything with no hidden charges??
the Chicago locals are mirrored to 129 also... so when you upgrade to the d1000 you will not loose them... all thats on those two locations are three Spanish stations.. one religious.. and channel 56.. The rest are avablie from 110 and 119. ;) most likely they will replace the switch :) and that would most likely be at no Charge ;)
what about regular HD channels....
Some Locals DOWN
