Check your HD DVR's ToDo list--Forced Software Upgrade to 02CB & 02B0 | SatelliteGuys.US
rad
Cutting Edge
Sep 7, 2003
11,651
6,133
Dripping Springs, TX
It appears that something happened last night. I have a couple HD DVR's that show nothing in the ToDo list. I know one of mine that rebooted for some reason last night. Over at DBS there's others reporting issues this morning, just wanted to mention it.
Added information:
The problem with missing ToDo list can generally be fixed through a reboot.
At 5:30 ET 2/11 DirecTV began a software push to the receivers to attempt to fix this problem:
There is no new notes / information for the updated software that is rolling out. It is a minor change that is targeting fixing the problems expereinced overnight with receivers losing their ToDo list.
02CA was a recent release that is not out to all receivers yet. These receivers are being updated to 02CB.
The original notes are here: http://www.satelliteguys.us/directv...r2x-r22-software-release-0x02ca-2-5-09-a.html
02AF was a release back in December that is on receivers that haven't been authorized for the new 02CA/B yet, and is being replaced with 02B0 immediately.
This release notes are here: http://www.satelliteguys.us/directv...-hr2x-r22-software-release-0x02af-0x02b0.html
Nothing was changed except for trying to fix the issue from last night.
Things some may see like the new Top Movies feature are simply verbage changes and a notification screen that were part of the 02CA / 02CB release previously.
My time was off, I exited out of the menu system and then all was well, including any recordings I had on the DVR. it looks like they added a new link for Hot movies or Top movies I think its called??
DAMN!
One of my HR20s has nothing in the list.
The other has nothing but two series links, everything else is gone.
WTF DirecTV!
I'm at work so I can't check. I'm anxious to see if my DVRs are screwed up. What kind of mickey mouse organization is going on over there. How many massive screw ups are they going to have?
I don't think it is software related, as it is affecting people with national release and test releases.
Looks like the did something wrong in the stream again. Third time in the past 6 months.
I'd expect a DirecTV issued reboot of all HR2x sometime later today :(
As for anyone at home, I'd reboot your box ASAP.
So far a reset has not brought back my Todo list, excluding things that are series links.
It appears that any single use timers I had set are long gone.
Just connected to the Slingbox and yep, my To Do list shows 0 items! I'm not going to be home tonight, hope I can manually record Lost or I'm not going to be too happy!
:Edit: After setting up the manual recording, To Do now shows 1 item
All my Todo's are still there.. I only do series links.. But the guide has got major holes in it in the days ahead.. Missing lots of program info on many channels
More evidence that the HR Series just isnt working. These guys need to go back to the drawing board.. better yet bring in Tivo sooner rather than later.
Our HR21 is faster than our TiVo, which is one of your complaints whenever you get the chance to voice it. Either way this isn't the thread for debating.
At midnight last night I had most of my guide go to 'To be announced'. Meant to reboot it but was tired and only had it on for background noise. This morning it's fine and I don't have any of the problems described in this thread.
I have a HR21-100. It was blank in th To Do List as well. I put most of them back in manually before I looked over here. I am rebooting right now but so far it has not come back up. I have a eSata terabyte on it so reboots are not always pretty. So far I'm on my 4th reboot.
Who mentioned speed and who's debating? This is an issue of reliability.
Give Up?
sat dish cable Length?
