check this out! a cheap(er) HD DVR solution? | SatelliteGuys.US
Fgsilva
803
Vallejo, CA
Hi,
I was doing some search for adaptor so that I can use my computer monitor as a TV for our boat and I saw this:
http://www.copperbox.com/lite/mdp120.php
Has anybody seen/tried this out? From what I understand, it only works for OTA signals. I also dont' know how much hard drive space you'd need for recording digital signal.
I've had the MYHD card for over a year and always loved it. I bought it because I wanted to see what HDTV was all about before I bought a 10K HDTV and my 19 inch plasma monitor was the only HD device I had. Now I have an HDTV and Dish 811 but if I want to record anything in HD I still need the MYHD card.
oh yeah i bought mine at the following site and they have the newest versions:
http://www.digitalconnection.com/
I've used copperbox several times and also like that is is almost around the corner from me for in-store pickups. I've had one of their fusion-dtv (non hd) cards for several years, now, and like it. Do recordings almost daily. Saves it in its own format, though.
Hey,
So, how much hard drive space do you need to, for example, record 2 hours of HD programming?
Thanks.
No HD-PPV on 921
322 remote code
