Check Switch | SatelliteGuys.US
Check Switch
phillyphil
36
Atlanta, GA
Hey Guys
For the last two weeks when I come home I get the error message that there has been an erro detected and I need to run a check switch. Any ideas as to what is causing this? I have a 522 and this message only shows on the tv2 location. As for dealing with dish, I find it repugnant to pay them $99 to fix their leased equipment.
Yesterday my showroom 522 gave a switch problem message. I ran check switch and it repeatedly said 1 tuner was seeing both satellites and 1 was seeing only 1. I disconnected DP-34 switch and just barrelled the connections to the Twin. It then tested ok. This morning I put the DP-34 back in place and reran the switch test the same receiver and switch is now testing OK. Just blame it on poor DISH software.
I have seen the DP34 switch "lock up" several times. The fix is usually unplug all receivers, plug 1 back in, do a switch check to verify, then plug the other receivers back in. The other receivers usually dont need a switch check.
Sorry about the lack of reply. I climbed up and snugged everything up and it appears to be working OK. I will let everyone know if this changes. Thanks for the assist.
Receiver power reset AND check switch will keep this bug away for the most part. Sometimes, a check switch will not suffice. You may need to take power off the LNB and temporary memory on the receiver before running a check switch. ;)
System upgrade for 510 causing freezing?
Uplink Activity Wednesday, October 19th 2005
