Flipping through the channels today, I noticed that Starfish and Pentagon no longer show up in my electronic programming guide. Probably some others missing, too, but those two are channels I watched occasionally.
no..do a switch test..you probably took a power hit
Do a signal level test on a couple transponders on 61.5..let it lock completely (on the signal) then do a check switchSwitch test shows all is OK.
I still get all of the sub channels I had on all three sats (119, 110 and 61.5).
Only lost some of the PI channels--still getting some of them.
I know it doesn't solve your problem, but I just checked and the channels you mentioned are still appearing for me.
Have you double-checked that the channels are not locked out? A while back I discovered that I had locked a channel and as a result thought I wasn't getting a channel in the PI pack.
Good luck!
Limited time offer
