ChannelMaster 4228 | SatelliteGuys.US
ChannelMaster 4228
klen
231
For those who have the Channel Master 4228 antenna, I was wondering how you like it, and what kind of "reach" it has.
I am midway between Milwaukee and Chicago and Rockford, IL, (all three are about 45 miles away) and I was wondering if it would be possible to pick up stations from both areas with that antenna. Does it reach out in more than one direction, and, if so, how far out? I can't always get the local Chicago Fox and ABC affiliates here with the Winegard yagi antenna that I have. (Voom upgraded it from the Stealth at no charge) Sometimes they come in, sometimes not. It seems that if one comes in, the other doesn't.
Any feedback is appreciated.
Thanks.
Thanks.
I pickup stations from LA 90+ miles away without a pre-amp. This antenna is awesome! Many others in San Diego pick up LA stations using this antenna.
It is mostly one directional though. The "bow tie" elements in front of the flat screen should point at the tower. It is also got a very narrow beamwidth so pointing it at the tower accurately makes a huge difference.
I have not tried this but some people swear that if you remove the metal reflector screen it can pick up stations in both directions if the towers are approximately 180 degrees apart.
I hope this helps!
Carlos
Stacking 4228's
I live 15 miles from the towers and about 60 feet below the lip of a hill. I use two 4228s stacked horizontally. See this web site for an explanation of stacking antennas.
http://pages.cthome.net/fmdx/stackant.html
I've also angled the antennas up about 10 degrees to compensate for the angle of the hill.
This set-up works great.
If I remember when I get home I'll post a picture of the set-up.
I use a Dish 6000 which has a fairly poor OTA receiver and average about 70 on the signal strength meter.
I hope this helps!
Carlos
Is it safe to assume that your 4228 is mounted on a mast or tower? I'd like to put one in my attic to pull in stations 80-85 miles away. I can currently get an NBC HD at that distance with a huge combo antenna in my attic, but only on a clear, cold night. What do you think my chances are?
My 4228 is mounted on a mast about 2 feet above my chimney on a 2 story house. So maybe 30 feet from the ground? I don't think you will be able to pull the stations through your attic. I could be wrong though.
I remember reading that composite or asphalt shingles on plywood roof are at least 6dB of attenuation. If this is accurate 6dB before a pre-amp really hurts.
Good luck!
We want to see the picture. It'll be interested to see how it looks.
DVI Cables???
I just signed up.
