Channel Satellite List | SatelliteGuys.US
charlesrshell
SatelliteGuys Crazy
11,251
5,981
O'Fallon, IL
Is there a chart that list all the Dish Network channels in numerical order with all the satellites that provide signal for that channel? See attachment for a sample of what I am looking for. Thanks
You can just use the guide that comes with the Dish service. Press the guide button and you'll see the channel # right next to the channel.
There are such lists for various packages on EKB.
If these don't meet your needs, please feel free to create such a list and post it.
I took a look at your Excel file and I liked the formating, so I put this together for you, I hope it is helpful :)
SatelliteGuys.US_TheList Dish Network Satellite Map
Wow, nice list qwert1515. Thanks. I think it is neat to be able to see at a quick glance which satellites for each channel. I noticed it has been added to "The List" section. Will someone keep it updated? I also noticed that channel 100 and satellite 77 was left off. Do you think they should be added to the new list too? Thanks again. Really nice job.
satellite 77 is not used here in the US. It is mainly aimed at Mexico. It has 3 transponders that are "warming" the satellite that are duplicates on 110
OK, thanks Iceberg. I didn't know if some of the southern part of border states and parts of Florida were using 77 or not.
Your welcome, I had a loop that missed the first item of data (Channel 100) so I fixed it :)
I help to update the FTA information for the TheList, and the subscription data is updated by Digiblur when there are major uplink changes. (Last Updated: 2/07/2008 9:22:04 AM EST)
OK, thanks. I am working on something else that would be nice to have in the list too, if it can be done. Will post in this same subject post by tonight sometime. Got to go run some errands.
Check out The List!
I'm not sure how this answers the question in a meaningful way. The List is all the channels on a satellite. The OP wanted the list in channel number order. One would have to combine all of the lists and sort them by channel number.
For the OP's purpose, going to the check switch screen to find out where the channel coming from may be sufficient.
Are you sure you clicked on the correct list harshness. I think the new list qwert1515 developed is outstanding and is exactly what I was after. Click on this and check it out.
SatelliteGuys.US - Dish Network Satellite Map
By default if you click on a link to TheList you will end up on the FTA section because that's what TheList was created for, later I added the Subscription section so you have to click the link at the top Subscription List Home and from that page you can click each satellite or the "ALL" link for each provider, yesterday after reading this thread I added the DISH Network Satellite Map.
Now a question about the SatelliteGuys.US - Dish Network Satellite Map are the "X"s the best way to show that a channel is on a satellite or would it be useful to put the transponder number instead?
WOW, that might be more good info for someone that is on one list. Would that be hard to accomplish and keep up?
Just ordered Dish! Couple questions
Can't move external Storage between vip622 receivers
