Channel Master Question | SatelliteGuys.US
bloomdog
306
I just used CM for the first time to load my Coolsat 6000 P with a bunch of new satllites. The problem is that when I look at my Coolsat for one of the new satellites, there are no frequencies imported. If I blindscan on a satellite, will it add the frequencies or do these need to be added manually. I have an extra tricky issue since I need a frequency for each bird so I can use Diseqc 1.2 to fine tune my aligment. ANy help?
yes it will add the transponders when you blind scan
you can add a transponder in Channelmaster
If you do the 1st option, check thelist for transponders. All you need is one to lock the signal :)
Where to buy DVBWorld products
is this a good deal or not
