Channel Master file that is up to date | SatelliteGuys.US
i4tas
791
4
Northern USA
Every now and then I find myself factory resetting my box so I can purge my system of old channels and bad transponders.
My box then reverts to the setting of 3 years ago, where satellites are named incorrectly and it can get confusing trying to remember the new/old names.
I am looking for a channel master file that has all c/ku sats with correct names and only the corresponding transponders that exist with signal (for the most part).
I say this because often I am trying to find a sat and I just move the dish until signal appears on TP1 for that sat, sometimes the TPs are wrong and i never find the satellite.
The file doesn't need to have any channels.
Thanks...
thanks for the file; exactly what i needed
Seems to be gone now
Sorry about that,
Here's the template I use and TheList in a Channel Master File (I think it works, but I can't remember and my receiver is not here so I can't check it :().
Well I got it all figured out! Here's My Setup
Signal Loss?
