Channel Master 4228 | SatelliteGuys.US
Channel Master 4228
jimmykce1
801
I have replaced the standard Stealth Channel Master antenna that comes with the Voom install with a Radio Shack 2016 (yagi style directional antenna). I noticed that I am still having only problems with channel 13-1 here in Newport News, Va. So I am thinking I need to get a better antenna. I was looking at the Channel Master 4228 (8-bay style).
I will need to install this in my attic on the existing bracket mount that came with the channel master stealth. I would like to know if its okay just to use the top mount only on the Channel Master 4224 or do I need to use both connects? Please give me some advice on mounting this antenna.
here is the only setup that I got to work for me in my area I could only pick up 2 or 3 channels and I tried a few different antennas I have 70 " trees and I am about 30 to 40 miles from the stations. 4228A 8-BAY EXTENDED RANGE HDTV-COMPATIBLE UHF ANTENNA Channel
this pre-amp really help me out , 7777 UHF/VHF pre-amp Channel Master
9521A Remote Control Rotator got these at http://www.warrenelectronics.com
hope that helped
My installation and questions
Sound sync issues (not the >1sec issue)
