Just noticed a channel for card exchanges 9458 CRDEX... it was not there earlier this aft....btw It gives me the you do not have authorization screen .
Saw some of those too...damn I feel like a real 921 owner now...Mark_AR said:Its been a noted intermittent problem on my 921 for several months now.
When it starts doing that, you will notice MANY channels that you've never seen before if you start going through your guide in the ALL CHAN list.
You will notice more and more of your subbed AEP channels turning RED.
Several LOCALS in the 7000's magically appear, and even TEST_CHAN I think on 5500 or somewhere around there. Even the International channels start showing up.
Power button reboot or pull-card reboot will fix it. It may be fine for months and then do it again.
Got it and a usb and jack of unknown origin... thanks... thought this was one of the new "cardless"receivers....and yes the slide door is not that obvious...n0qcu said:the card is in front lower center slide open door. (and if you can figure those directions)
dfergie said:Got it and a usb and jack of unknown origin... thanks... thought this was one of the new "cardless"receivers....and yes the slide door is not that obvious...
Limited time offer
