CHanging UHF(6.0) remote to IR remote | SatelliteGuys.US
Pula
6
Hello All
I just purchased and successfully connected a 625 and 510 to one TV(multiple inputs)..this is so I can record 3 shows at once(and yes I know.."loser")...everything is connected Sweeeet..and now I'm setting it all to my personal likings....BUT...
One question..I'm using the 625 and 510 on one TV(so I can record 3 shows at once)..but I'm not having much luck with changing the UHF #2 remote to an Ir remote...(when I simply flip the blue(UHF) to green(IR)..it becoems IR but for the TV1 address...I need it to be IR for the TV 2 address....
Ideally I want all 3 addresses to be IR so I can then program my SONY(IR learning remote) Remote commander(with the 3 IR remotes) to Learn the signals..thereby no longer needing the 3 remotes..just my handy Universal... Any ideas...
Yes I believe the Sony only takes IR signals(pretty sure of that)and its Universal....and has worked with the 510 flawlessly...
Anyone got any ideas...or is this obvious to the rest of you and I'm just "special"...
Thanks again..
How to add a Dish 625 to my current Dish 510 system?
IR Blaster On 622
