Changing polarity on Chaparral feedhorn | SatelliteGuys.US
olegray
SatelliteGuys Guru
131
w. arkansas
Without using an old analog receiver, can the polarity be switched as needed? It is the 5volt, three wire black for ground, red for 5 volts, white for pulse Chaparral feed horn with a Drake 2766 lnb.
There are "Automatic Polarity Controllers" available. About $40. I've seen them on Ebay but not at the moment. They can be self powered or run off a power supply.
olegray said:
Talked with Rick, and sounds like what I'm looking for. Thanks Fat Air & Magic Static.
I tried to search for the specs someone posted the design and how to build one could be a fun project. Any ideas?
One day I would like to build one to play with my older LNB's.
C-band a la carte
Finding Analog Satellites
