kelleyga SatelliteGuys Pro Original poster Aug 13, 2005 320 0 Sep 28, 2005 #1 Can I buy an antena so I can control/change channels on my pansat 3500s in the living room from my bedroom?
dogstar1313 SatelliteGuys Family Sep 7, 2005 100 0 Tennessee Sep 28, 2005 #2 I'm pretty sure you can get a UHF remote kit for the 3500S and most other Pansat receivers that will accomplish what you want.
M Mr Tony SatelliteGuys Pro Supporting Founder Nov 17, 2003 3,447 15,093 Mankato, MN Sep 28, 2005 #3 yep. There is a UHF remote option (I use to have one) pros-can control it from another room, different remote so you have 2 remotes cons-buttons are small and in different spot than normal remote
spindoctor SatelliteGuys Pro Jun 5, 2005 174 0 Sep 28, 2005 #4 have a look on ebay this item i bought one from him the cheapest around 5812049184
M Mr Tony SatelliteGuys Pro Supporting Founder Nov 17, 2003 3,447 15,093 Mankato, MN Sep 28, 2005 #5 same person I got mine from (paid a little more than that though)
bigOleB SatelliteGuys Pro Supporting Founder Jan 27, 2005 1,708 0 SC Sep 28, 2005 #6 Using one right now. It works great as long as you don't have any other wireless devices causing interference.
