Change Skip Duration? | SatelliteGuys.US
Slip goes forward 30 seconds showing the video as it goes. It takes a couple of seconds. The skip is virtually instantaneous.
FYI, when you change the from slip to skip you aren't really programming the remote for that functionality, you're telling the DVR how to respond to that button.
Put 30skip into the search function. It will change.
slip is the default. I don't think the skip is actually supported.
DirecTV's Tech Support folks are GREAT!
sports channels
