CE's for Sept 28/29 | SatelliteGuys.US
CE's for Sept 28/29
I'm taking the quick way out tonight.... I am just cutting and pasting, and not altering the posts... in brewer's manner... one of the SatGuys can modify this with in the respected manner.
Earl whats up with the HR20-700 release I am banned from DBSTalk and cant look for myself. :)
HR20-700 {CE:09:06} - 0x1A? Announcement
Systems in this CE / Version
Windows of opportunity to download:
Friday; September 28, 2007 11PM - 2:30AM ET
Saturday; September 29, 2007 11PM - 2:30AM ET
Download Probability: 90%
Be sure to monitor the threads and chat room to check on final availability
While you are waiting for the Window to open:
MUST READ AND AGREE TO: - The CE Rules, Faq and Tips Thread... Here
Please join "us" in the CHAT room, about 15 minutes before the window opens... and till... well to the last person turns off the lights...
DBSTalk.Com -
The Contents of the Release: (Differences based of 0x18a National Release)
Items from CE:09:01
Items from CE:09:02
Items from CE:09:03
Items from CE:09:04
Items from CE:09:05
Items from CE:09:05a
Items from CE:09:06
Improved
Prioritizer Screen
Navigation to PIG (Picture In Graphics) removed. (Trick Play Still works), to improve interfacing with UI
Stability
Several user interface polishing and fixes based on CE reports
DoD: Misc. Reported issues fixed
DoD: Performance improvement
User interface polishing
DoD UI: Restored CHANNEL UP/DOWN in the Homepage Left Menu.
DoD UI: Homepage "tuning" fix for consistent prevs channel
DoD UI: Added "On Demand" to quick menu after "My Playlist"
DoD UI: UI Polishing/fixes
Caller ID (no specifics on what)
UPnP issue that certain networked Cameras could crash the box.
A plethora of fixes to issues identifed in the previous CE's
Several UI Fixed and Polishing
Fixed the CE Introduced issue with items in the ToDo List, but ultimately not recording
DoD UI: "More VOD" in ever page
DoD UI: Misc. Items
DoD: Corrected - Not being able to resume playback of a currently downloaded program
DoD: Corrected - Listing performance
Updated
History list now includes conflicting program
Unwatchable content is no longer kept in the disk
New feature(s)
Keyword search finds category (eg HDTV or sports)
Caller ID for Type 2 (aka Call Waiting, off-hook, ect); Caller id reverted to 0x18a version
Start/resume to manual
Left arrow mimics "BACK" when practical
Long channel name in search by channel
Ability to hide SD channels if duplicate HD channel with same number exists
Support for Remote Booking
DoD: Pressing INFO when over the DoD channel goes directly to the "ALL" List
Notes
There are other misc. updates in the release
GUIDE DATA WILL NOT BE CACHED they are enhancing pieces of the guide data, which means you WILL LOSE your guide data after the install. It will repopulate over the next 20-24 hours.
This is only valid if you are comming from 0x18a, if you are on 0x19* you are not expected to lose your guide cache
DoD GUIDE DATA will most likely be lost after you reboot the system.
This is the sixth CE in the cycle... So the risk level is lower then the previous ones, but there is still a risk involved. Please only download this CE release if you are willing to take that risk
Note to other sites and users of those sites:
You are permitted to copy this CE Announcement in it's entirety (including this disclaimer) without modification so long as you provide a clickable link to DBSTalk.com.
DBSTalk.Com
D11-800 {CE:08:02} - 0x103?
Window of opportunity to download:
Current Probability: 90%
DBSTalk.Com -
The Contents of the Release: (Differences based of Last National Release)
  • Items from CE:08:01
  • Items from CE:08:02
Improved
  • Minor UI corrections in the menu
  • Minor UI corrections for parental controls
  • Auto-tune now behaves correctly in standby
  • UI corrections for large remote control code lists
  • OTA pass-thru now works correctly in standby
  • Stability
Updated
  • N/A
New feature(s)
  • Mini-Guide feature
  • Additional buttons to exit stand-by
Notes
  • Misc. Fixes based on CE reports
H20-600 {CE:08:04} - 0x203?
DBSTalk.Com -
  • Items from CE:08:03
  • Items from CE:08:04
Improved
  • Guide speed performance
  • SWM Tunning
  • Interactive MLB/NFL channels
  • XM Channel stability
  • System self-diagnostic
  • Search results
  • Game Lounge Performance
Updated
  • ATSC guide fixes
  • Video stability fixes
New feature(s)
  • SWM Support enabled
  • One Button Guide Toggle
  • INFO hold -> Jump to System Information Screen
  • Additional key presses on remote, will bring system out of standby
  • Program Guide now displays more then 4 characters of channel short name
  • Option to hide SD channels if HD channels are available
Notes
H21-200 - 0x402?
Version Push
Scheduled: Evening of Friday; September 28, 2007
Items from VP:01:07
Improved
  • Search results
R15-100: {CE:08:05} - 0x108?
Friday: September 28, 2007 11PM - 2:30AM ET
Saturday: September 29, 2007 11PM - 2:30AM ET
DBSTalk.Com -
  • Items from CE07197 (R15-300 Only, R15-100 didn't participate in this version)
  • Items from CE07201 (R15-300/500 Only, R15-100 didn't participate in this version)
  • Items from CE07208
  • Note: Depending on where you are, you may have a different national release, that may already contain some of these features
  • Items from {CE:08:01}
  • Items from {CE:08:02}
  • Items from {CE:08:03}
  • Items from {CE:08:04}
Improved
  • Under the hood improvements
  • Faster channel change time
  • Stability
  • Live Buffer in Standby
  • Enabled EXIT button in Signal Meter Screen
  • GameLounge support improved
  • More under the hood imporvements
Updated
  • Temperature reading in Fahrenheit instead of Celsius
New feature(s)
  • [STRIKE]Front panel guide/filter toggle[/STRIKE]
  • Guide/Filter toggle option in Display Setup Screen
  • White GUI
Notes
  • N/A
R15-300: {CE:08:04} - 0x10A?
DBSTalk.Com -
Improved
  • Stability
  • GameLounge support improvements
  • More under the hood improvements
Updated
New feature(s)
  • White GUI
Notes
  • Misc. under-the-hood items, and issue found in previous CE Release
R15-500: {CE:08:04} - 0x115?
DBSTalk.Com -
Improved
  • Stability
Updated
New feature(s)
  • White GUI
Notes
No CE Tonight?
HR20-700 {CE:09:06} - 0x1A3 Discussion thread
