CBS HD O&O PROBLEM | SatelliteGuys.US
CBS HD O&O PROBLEM
BCSA5115
10
Delaware
I Live in Central Delaware. I live in the Philadelphia DMA and I wanted to get CBS HD. I was told by dish Csr that I need premission from Salisbury DMA WBOC. I tried contacting WBOC and they say that they can't do anything and want me to call back dish to ask them for CBS HD. I am getting thrown between both of the representatives. How can I get CBS HD?
Be sure you are within the grade-B contour of WBOC (which determines whether or not a waiver is required). D*'s distants site is better at this than E*'s:
http://directvdnseligibility.decisionmark.com/app/AddressEntry.asp
Enter your address, and it will name (by call letters and channel) the network stations you are in the grade-B contour of. The E* site only says you do or don't qualify for distants from a particular network; D* gives names.
If WBOC is NOT on the list, call E* and ask them what information they have to show otherwise.
If WBOC is on the list, call WBOC and keep escalating the issue until you can get someone who will listen (maybe the station manager?). Basically, you need someone who understands that even though you're not eligible for LIL from Salisbury, you're still in WBOC's grade-B contour and thus need a waiver from them to get HD distants.
Do you get to keep equip.?
Top 10 Reasons NOT to buy a 921 till March 1st
