cbs feeds with 36 inch ku band | SatelliteGuys.US
tracybuffalo
10
iam new to free to air and i noticed on lyngsat that there are cbs feeds on ku band. i believe they are on 93w . if so will i be able to recieve them easily. i have the correct lnb . any input would help .. thanks:confused:
yes you can but also be advised that when looking at the charts at lyngsat that feeds means that they might be there or they might just pop in and out. some of the other channels are up most of the time but usually grey ones marked feeds means they use these to transmit wild feeds.
and welcome to the group
Satelliteguys 4th Anniversary thoughts
If You Had to Buy a New FTA Receiver
