If they were, I would even dream of using it. The new CUI make the H2000 dreadfully slow.Is Dish still offering carbon ui software in the stream, for Hopper 2000?
Isn't "CUI" Carbon User Interface?If they were, I would even dream of using it. The new CUI make the H2000 dreadfully slow.
I used it on more than one H2000, can't get it on a H2000, that I currently have, even with the force updateIf they were, I would even dream of using it. The new CUI make the H2000 dreadfully slow.
Yes active, but I cannot get the CUIIs the H2000 active on an account? CUI should be the only software available.
That's more like it, get it before on other H2000There was a message about a month ago that they were going to stop updating those. Maybe they actually did something that they said they were going to do
I installed a lot of receivers with CUI, I don't have any problems, most of the slowness is worn out hard drive"Offering?" "Forcing" is more like it.
Count your blessings and don't bring it down upon yourself. If I could dump it and go back to the previous software, I would.
110,119 & 118I just noticed that your location is Jamaica. What satellite orbital positions are you receiving?
110,119 & 118
Boot recovery, changing hard drive, sleep mode, just about everythingDid you try a boot recovery?
I done a lot beforeThe reason I asked is that maybe they moved the download but if you're getting 110 and 119 you should be getting the download stream. Have you tried the boot recovery?
Maybe no more CUI for H2000, thanks for your helpWOW, if a boot recovery didn't get it then it must not be there. Did the boot recovery finish? I noticed that lately the boot recovery takes a very long time but does eventually finish with the latest production software.
Limited time offer
