I icu1954 SatelliteGuys Pro Original poster Sep 1, 2010 275 0 lower alabama Oct 30, 2013 #1 does a captive works 600s support AC3?
turbosat SatelliteGuys Master Dec 26, 2006 9,003 82 Oneonta,AL Oct 30, 2013 #2 Does it have an coaxial audio-out jack or optical (spdif) jack? If so, I'd say it would pass the signal to external processor. Doubt any of the SD boxes did dolby sound though, don't recall any.
I icu1954 SatelliteGuys Pro Original poster Sep 1, 2010 275 0 lower alabama Oct 30, 2013 #3 audio out jacks
KE4EST SatelliteGuys Is My Second Home Staff member HERE TO HELP YOU! Lifetime Supporter Aug 9, 2004 27,035 7,364 EM75xb Oct 30, 2013 #4 No it does not, also that box was designed for hacking. That box came out in 2006. I would look for a newer box.
S straffer44 SatelliteGuys Family Oct 30, 2013 36 9 peterborough, ontario Oct 30, 2013 #5 It does support ac3 through the optical jack.
KE4EST SatelliteGuys Is My Second Home Staff member HERE TO HELP YOU! Lifetime Supporter Aug 9, 2004 27,035 7,364 EM75xb Oct 31, 2013 #6 Oh it does, I did not know that. Good to know.
KE4EST SatelliteGuys Is My Second Home Staff member HERE TO HELP YOU! Lifetime Supporter Aug 9, 2004 27,035 7,364 EM75xb Oct 31, 2013 #7 straffer44 said: It does support ac3 through the optical jack. Click to expand... BTW Straffer44, Welcome to Satelliteguys!!!
M Mr Tony SatelliteGuys Pro Supporting Founder Nov 17, 2003 3,410 14,950 Mankato, MN Oct 31, 2013 #8 ke4est said: That box came out in 2006. I would look for a newer box. Click to expand... no sh*t. I had one and it SUCKED for free to air. DOnt even try and use a motor with it..it doesnt work right
