Can't see sat 129 | SatelliteGuys.US
Can't see sat 129
bluezbear
33
Atlanta
Help! I can't see sat 129 from my house. That sucks. I have the VIP 622 and now receive HBO-HD but nothing else.
What HD channels are available on sats 110 and 119?
I would like to get ESPN-HD.
http://ekb.dbstalk.com/dishlist.htm
Check that page, then do a quick text search for TND HD and that will take you to the HD channels section (or go to channel 9420). You should be getting more than HBO HD if you can see 110 and 119. Since you can't see 129, you might want to try 61.5, but I think ATL HD locals are on 129 (but I could be wrong)
Edit:
Dang beat me by 1 minute)
And yes, I just looked, the ATL HD locals are on 129
110°:
ShowtimeHD, HBOHD, ESPNHD, HDNET, DiscoveryHD, TNTHD
119°:
None
If you cannot see 129°, have Dish add a second dish pointed at 61.5°.
You have to have changed your programming package to one of the metal HD packages in order for your 622 to receive HD channels. (HBO is a Prem channel)
TNTHD, Discovery HD, HDNET, HDNET Movies, ESPNHD, HBOHD, and Showtime HD are on 110.
IF you can't see 129, all of the 15 Voom channels, ESPN2, and Universal HD are on 61.5.
The problem you will run into with the 622 is they won't authorize the old HD pack. Only the new metallic packs which include all of the HD channels (except HBO and Showtime. You must subscribe to those channels then you get the HD feed for free. Like you do HBO).
Have a great weekend.
Scott
Your down here in the southeast like me so you will probably be better off with a dish @ 61.5W than @ 129W. You'll get alot better signal strength with 61.5
Ciel 2 to launch in 2008 to 129
HELP - My 622's TV2 RF out has overmodulated audio!
