cant get Verticals | SatelliteGuys.US
cant get Verticals
airplane777
6
I have a INVACOM QUAD QPH-031 QPH031 LNB. I am trying to set this LNB to work with my CoolSat 6100 private FTA unit. I am able to pick up the vertical polarity channels, however I am not able to pick up the ones that are Horizontal. I have an LNB input voltage of 19 volts, i need to set it to 13 volts, this is supposed to to change the LNB configuration from vertical to Horizontal. I can not find anywhere in the settings to adjust the LNB voltage.
I'm not sure what you're saying, there isn't a way to just set the Coolsats to Vertical. But, if you do a Scan, you can set the "Pol" from "ALL" by using the left/right arrows. There is a V for vertical and an H for horizontal, but it will default back to all when you're done.
need info on receiver
123w Galaxy 10 the LIST
