Cant get H polarity | SatelliteGuys.US
Cant get H polarity
tommy_lmt
My new 17K LNB cannot get Horizontal Frequencies. What is the problems? Please Help.
I assume you are talking about a C-Band LNBF? I broke this off from another thread on the assumption that is what you're working with. (I think C-Band is the only thing that uses K on a scale) :)
What is the current setup? Receivers? DIsh size, etc?
The type of lnb will help also? Is it an lnb or is it an lnbf? If it's an lnb, then it could be a bad servo motor (polarotor). It could be something with the wiring. You can test the servo motor by simply turning the lnb 90 degrees inside of the feedhorn assembly. An lnb will change polarity if you turn it 90 degrees. An lnbf will not do this. If it's an lnbf, it could be you have your receiver set-up wrong in the menu? What kind of receiver do you have? The kind of dish will only matter if it's too small. For C-band you need at least a 6' dish, I would recommend at least a 10' dish.
Al
240cm Fortec prime focus performance
Help Identify Satellite
