Can't get ESPN hd and other channels on Sat. 110 | SatelliteGuys.US
Chris1523
16
Hi all,
I'm new to the forums. My problem is that basically whenever it rains I can't get espn hd, and any other channels on sat.110 transponder 7. I did the check switch and it has everything says ok. I could receive the other hd channels fine. I'm not sure if I should call Dish Network, or wait.
Thank you.
To me it soulds like you have a weak signal on the 110 and thats usually what happens when the signal isnt high enough. what kind of signal when you check it?
The signal I'm getting on transponder 7 is around 5. When it's clear outside and there's no clouds, my signa will go up to around 15. I have no idea what's the matter.
Thank you
Thank you
15 is way too low. I'm getting 47 on TP 7 so your dish needs re-alignment. Call Dish Network and explain the situation or if you're brave enough we can walk you through it.
Legacy and SW21X - Error 004
Activation - 2 hrs and counting...
