cant get any quality | SatelliteGuys.US
i have the viewsat extreme and the motorized fantac dish,i get signal but no quality
from the post "posting guidelines" (the stickey at the top)
With a lot of newbies getting systems and needing help setting up, please help us out when creating posts (this goes for the veterans too)
If you are having trouble with your setup,
PLEASE PLEASE PLEASE PLEASE list your setup (what receiver, LNB, dish size and motor if applicable you are using).
If you are asking "my numbers are 36 elevation, 177 azimuth and -20 skew…is this right?" Please post location (city & state or zip code)
Many posts the first response is "what are you using for equipment" or some posts don't get answered because it's too vague. The more info you give, the better we can help out….
We can't read minds
Thanks for your understanding….
-Berg
With the limited information, one thing I can suggest is that you remove the motor and try to hit some satellites with the dish fixed-mounted on the pole (no motor). This will give you an idea of the mechanics behind aiming at the birds you're trying to hit.
Moving Dish With Traxis 3500 Question
Motor setup when True South is Blocked
