I have noticed that if I am watching a show and 30 min into it if the show is for 30 min I hit rewind to the beginning and hit record I can not. Why is that? Anyone notice this crappy 922 can not rewind and record the program you want?
I've seen this too on my 922. I don't think it has anything to do with a reboot.
It appears the use of live buffers has been castrated. Or at least majorly modified from 622/722 behavior. The program guide appears to control when the record button will work or not.
So if you paused a show 15 minutes into a half hour show. Went away for a half hour (kids, life, food, other tv input, anything) and realized that you want to record the rest to view later, you are hosed. If the program guide has gone on to the next show, you can press the record button until your face turns blue, nothings gonna happen.
Particularly sucks for things like sports, playoff hockey can go an indefinite time, program guide info never matches it. Program guides get out of sync all of the time in my experience being a Dish customer... now there is just a penalty to it.
It seems to coincide with the no manual timers. This is a big gotcha that I haven't seen described in any of the existing threads so far. Can't really call it a bug, as it appears to be as designed. Since all of the recordings show a funky little icon for each show.
On the 622/722, it would just record under the follow shows program info. That might not be granular enough for Dish/Sling/Google/Media Providers so they neutered the behavior. Hopefully as the software revs come out, they will add back in manual timers and full buffer functionality like recording to disk what's in it.
Note this is all my speculation, but this is what I've observed and would explain what you see in using the live buffers.
So far, with the 922, I have to set everything I might want to see to record, as auto-tune is too risky if you just tune it in live, pause it for the hour, if the prog info changes, bye bye.
Hope this helps.
Limited time offer
