Cannot Get Through Satellite Setup. | SatelliteGuys.US
Mattr652
6
Hi, I have been having a problem where the signal strength on Satellite 101 gets a signal >95 on every even transponder and a signal of 0 on all of the odds. Currently I have three boxes that are working, and able to receive some of the channels. The fourth, an HD receiver, was working but got unplugged. Now it is able to detect the alternating signal strengths on the transponders, but when going through the setup it is "Unable to detect a satellite signal"
I am unable to get to my dish without going through a major ordeal due to the fact that it is mounted on an 8foot pole on top of my roof. I believe the dish is a Slimline 5LNB, not the SWM type since the HD receiver was installed with a B-Band converter.
Any suggestions as to what could be causing this issue?
It also could be a bad ground block.....i had one today:rant:....it did the same thing to me today, i got all the even transponders but no odds changed the ground block and presto all the transponders or like fed up said a bad lnb
DirecTV TiVO HD 2010
New HD DVR
