Can you put an 18" dish network/dtv lnb on a 30" dish along with a KU lnb? | SatelliteGuys.US
mastermesh
1,988
Just curious if you can put both lnb types on one dish to pull in both ku and the freebie echostars on one motorized dish?
Sure can, most members use a hose clamp, a zip tie or good old duct tape!
Rock on. Cool. Thanks. That'll make life a lot easier when that motor and dish get here. I'll just take the lnbs off of those 18"ers and have a new pallate for my paints :)
I've done it a few times :D
If you put the DBS LNB to the left (if behind the dish) then the DBS is +4 from the KU slot
If its to the right then its -4
(as an example, 1st picture is 123 & 119...closer LNB is 119)
What Am I getting Into
how to add attachments
