Can you place order for 2nd dish install over the phone? | SatelliteGuys.US
The Dish300's can be had for very cheap. The bad thing about it is that most of the used ones that can be had for cheap have a legacy lnbf instead of a DishPro lnbf. I would imagine that a DishPro lnbf can be had for cheap as well. If you cannot install it yourself then you might be able to find someone to install it for cheaper. If you cannot install it yourself and have to buy a DishPro lnbf and switch you might as well just have them do it for $100 with all the costs involved. Does this deal include any switch that would be required? What if someone has a SuperDish? Would that include the DPP-44 or just the dish and install only?
From what I've read on here it doesn't look like the $100 would include any switches outside of maybe a 2x1 (SW21 or DP21). If it did though, that would be a steal. :)
61.5 with 105,110,119
121 SD and Locals question
