B bryansr SatelliteGuys Pro Original poster Jan 21, 2005 272 0 S. D. co. CA. Jul 10, 2005 #1 Can you use a Dish 6000 to pick up the VOOM channels? Thanks BryanSR
dfergie Proud Staff Member Staff member HERE TO HELP YOU! Sep 8, 2003 105,588 10,160 West of the Pecos, between White City and Roswell Jul 10, 2005 #2 Yes... I get them with mine...
B bryansr SatelliteGuys Pro Original poster Jan 21, 2005 272 0 S. D. co. CA. Jul 10, 2005 #3 Thanks... I am about to get on off Ebay.....
dfergie Proud Staff Member Staff member HERE TO HELP YOU! Sep 8, 2003 105,588 10,160 West of the Pecos, between White City and Roswell Jul 10, 2005 #4 Make sure it comes with a card, and card has zero balance ( ppv's etc) against
R rcbridge SatelliteGuys Pro Sep 22, 2003 583 0 Limerick Pa Jul 10, 2005 #5 Also make sure you have access to the 61.5 degree location!! And be leary about buying a used receiver on e-bay!! It may be fine but you never know!!
T T2k The Raw Nerve Supporting Founder Jun 5, 2004 1,856 0 Park Slope, NYC Jul 10, 2005 #6 Mine is working fine, though 720p produces purple lines in some channels, so 1080i...
B bryansr SatelliteGuys Pro Original poster Jan 21, 2005 272 0 S. D. co. CA. Jul 10, 2005 #7 Thanks for all of your input.... all is OK....
dfergie Proud Staff Member Staff member HERE TO HELP YOU! Sep 8, 2003 105,588 10,160 West of the Pecos, between White City and Roswell Jul 10, 2005 #8 Be aware that the guide is slooooooow and it does have some quirks...
DarrellP I Think, therefore, I am. Supporting Founder Nov 6, 2003 4,298 0 Salem, OR Jul 12, 2005 #9 Also make sure it has the 8psk module or you are up a creek without a canoe.
