Can You Help With G-Box Programing | SatelliteGuys.US
  • Thread starter Thread starter Pixl
  • Start date Start date
  • Replies Replies 0
  • Views Views 1K
Pixl
Senior Member
1,902
67
Traverse City, Michigan
I've been struggling with a new G-box v3000 setup. 1st problem, I'm using my receivers diseqc 1.2 menu to store sat positions. A position label pops into the G-box display. My most easterly sat NSS10C @ 37.5 shows up as position "P-09" . Ok so far, and I can reliably recall the sat with a receiver channel change. As I program to the west, next sats show as P-12, P-13, P-18 on up to P-24 then next sat is P-04 ? When I get to my 11th sat it puts in P-13 again which was already assigned and swings the dish back to 45deg. ?? I don't seem to have enough "P" addresses.
2nd problem, I was re-naming the sat labels using the G-box remote control and made a mistake. But I don't see how to delete the entry. There are only 30 label positions and I will need them all.
Jim
Prof Revolution s2 7500 USB DMX741U no signal
Good signal and no quality with Sonicview 360 Elite
