Can you do FTA with one of These? | SatelliteGuys.US
yes
If you can use it, then go get it.
Even if you offload it to a friend later for the $20, it'll save someone a bit of money.
36x24" ?
I think this is what you've got there.
I was playing with that dish last week it works fine on, Galaxy 3 95.0 w, Galaxy 19 (T5) 97.0 w , AMC 4, 101.0 w
I hat hard time getting the Equity Broadcasting channels from Galaxy 18 at 123.0 w
I had trouble with 123 on a modified Superdish (same size as world direct dish) when 125 came on line last summer. Ended up going to 1.2M dishes for those two birds. It should be fine on the others. I recommend 129 for White Springs, even though not everyone would agree....LOL
Nice little dish to have for linear and circular separated by 6 degrees.
I.E. 123 for Equity and 129 for what was once FTE WOUB but as of now no more.
It would work as an Equity/Whitesprings dish if I could find a linear that can fit in the small space of the circular LNB. Good find! :)
Good one to try and motorize as well. (I'm thinking about trying it) Makes for a good "poor man's invacom".
Just gotta keep in mind the 6 degree difference between both LNBs.
MTV/Viacom situation
Newbie
