Can this riddle be answered???? | SatelliteGuys.US
kuzn
4
Illinois
Can a triplesat or 5lnb at9 dish be put into a diseqc? I am not farmiliar with the diseqc switch and am not sure if you have to use a dual lnb for all ports on the switch in order to make it work, or can you use a multisatellite antenna into this diseqc switch and will it be able to cycle through the 101, 110, 119 and so on using one port on the switch or do you have to put the 101, 110 and 119 all on seperate ports on the diseqc switch. Also I had a question about using a triplesat with a 1 room reciever install. Can I use a 22k switch for say the 101, 110, 119 on one port, and 72.5 on the other port and will a directv reciever be able to switch between the four satellites?
You'd need to put the 101 into two ports of the switch and then put the 110/119 combo into two other ports... but that leaves no room for the 72.5 satellite.
Remote Flying Through Channels
Sun.Feb.18 Ride Shotgun For Free with DirecTV!
