Can this be done...without damage | SatelliteGuys.US
8valve
65
Adirondack Mts
I have a question, so I dont blow anything up. Equipment in Question; GeoSat Pro 200 Receiver, Coolsat 5000 Platinum Receiver, DG 380 Dish Drive using USALS, Please keep in mind that at NO TIME will both receivers be turned on. I have the Geosat 200 in my Living room controlling the Dish Motor. Can I run a RG-6 from the LNBF loop OUT on the Geosat to a Coolsat in my office. I want either receiver to control the dish motor. Remember, only one receiver will ever be on, the other will be turned off. Can this be done....or is it Smoke time LOL. Thanks 8Valve
i have done this successfully in the past....it has worked and very well....i was using different receivers than you....but it did work for me....no harm in trying as long as they are never turned on at the same time....
yes it will work just fine
and even if both happen to be on at the same time you wont blow anything. Only the main receiver (the 1st in line) will work properly. The 2nd one will only get the same polarity as the 1st receiver us on
Iceberg; You said; "Only the main receiver (the 1st in line) will work properly. The 2nd one will only get the same polarity as the 1st receiver us on" Are you saying this will happen if both receivers are on ? Or if the first receiver is off but on standby ? What if the first receiver was totally powered of, would the second receiver than have full authority for polarity ? Thank You 8Valve
yeah forgot that tidbit...brain thinks faster than the fingers can type
if both are on then "The 2nd one will only get the same polarity as the 1st receiver is on"
I do this all the time with two Visionsats while recording NASA coverage of shuttle missions. Typically, one receiver is recording from an SD feed while the other records HD. Since both are on the same transponder, there's never any conflict. One thing I found out is never turn either receiver on or off while recording with the other, as it will cause a bad glitch.
Best firmware for the sathawk family of receivers
SonicView HD8000 Screen Capture
