Can the 722 use legacy equipment for HD? | SatelliteGuys.US
zieltom
6
Does Legacy technology work with a VIP 722 receiver? I have a Dish 500 pointed at 119 & 110 and a dedicated dish pointed at 61.5 and all LNB's are legacy. I'm currently running a (2) 721 and (1) 5000 receivers. The VIP 722 which I'm waiting for will replace the 5000. I'm using (6) 2 way splitters each with a power pass port and a DC blocked port, (2) sw64 switches and (3) Feed Through Loads to supply the signal to my receivers. The receivers recognize the switch matrix and see all 3 satellites with strong signals. Thanks for your feedback!
Are you telling us or asking the question? The 722 will work with legacy LNBs but you must run 2 lines to the 722. Both lines need all 3 birds so you would need a SW64 switch. Lots of cable and lots of work.
Need equipment recommendations
texas locals
