Can my ViP 722 HD DVR Run on 3 Televisions? | SatelliteGuys.US
claytonboen
68
Right now I have it on two televisions... But my quesiton is...
Can I run a splitter and split the signal going to my 2nd television, and have it also go to a 3rd (and 4th, 5th, etc)? I understand that the 2nd and 3rd television would ALWAYS have the same program on...
But is it possible? If so, I could save $7.00 a month by returning the HD receiver I have in my office and just carry the remote back and forth from the bedroom.
I have mine split to 8 TVs and it works fine, remove the attenuator on the receiver output if present. I bought a half dozen 8.0 remotes on Ebay for the other rooms.
yes, I run 3 off my second tuner and just put a remote in each room.
You don't even need to buy additional remotes if you don't want too. I have my tv-2 feeding 5 other tvs and since I live in a one story house, basically it is no big deal to take the remote into the other rooms, or into my garage (yes I have satellite tv hooked up in my garage:D)
New Install My-O-My
DISH Network® Becomes Exclusive U.S. Provider of TV Silesia and Radio Silesia
