can i use this dish for both c and ku, newbie here | SatelliteGuys.US
lilmale1
5
mission viejo, ca
im planning on installing my first real dish
something that will work with cband a kuband together
i know i will need a 6 foot one
but does anyone know if there is chance i can use this dish
from ebay right now for low price 33" dish universal lnb 33/39
what are my option with this channels
for some of these channels or most of them >>>>>attatched
no:
Your question was confusing, but let me answer one part.
You probably won't be able to receive anything east of about 50°w from Southern California.
Too low on the horizon. Down around 10° elevation.
And you most certainly will not get 30°w!
It's below the horizon.
ok.....
ok, so i can only use that 6' dish
or somthing. im not quiet understanding what dish i need for what elevation
im in south orange county
what do u recommend of what dish
i did some research and.....
i see if i use a dvb card i will be more organized
but my option are limited on what dish i should get for these
since I already have a card with ini files for these
i should get a dish for them
ok for dvb-s files i only fournd
15w TvRadio,
30w Radio,
40.5w TvRadio,
43w TvRadio,
45w TvRadio
58w TvRadio,
61w Radio,
72w Radio
that are being supported daily
and now i wonder what i can use for this
so what is my best options considering they varie from deggree
don't understand the "ini files" ref, but it won't matter what dish you try to use, if the satellite is over the Asian continent, your dish cannot see it from California. Satellite broadcasting is line of sight-the dish has to be able to see the satellite to get the signal, and most of those satellites would be below the horizon for you, due to curvature of the earth.
Cable Innovations Series 200 Won't move Dish.
Newbe question on HTS receiver
