Can I use Panasonic Powerlne adapter for DishComm? | SatelliteGuys.US
its4us2think
33
I want to know if I have setup the powerline using the panasonic HD-PLC, can that work with the 722's in built powerplugg/DishComm?
Or should I buy one more powerline adapter and use the ethernet
It doesn't look like that model is HomePlug, so it would not work directly with the 722's homeplug chip. But if you have two of these Panasonics, you can just connect one of them to the 722's ethernet port and use it successfully that way.
Just "moved"... forgot about the time zone issue.
newb here: On Demand/Starz On Demand/Showtime Interactive questions
