can I use a LNBF on my old feedhorn | SatelliteGuys.US
chuckinnc
29
2
Western,NC
I have a deep dish and want to keep my scaler ring/ feedhorn setup, maybe change out the lnb with a lnbf? I am thinking if i remove the pol rotor arm it
may work. If not then is there any way to get one of the lnbf/scaler ring combos
to work on a very deep C band dish, about .26 ?
an lnbf is simply an lnb with the feedhorn built in. if you can remove your old feed horn from the scalar than you can replace it with the lnbf. if the feed and scalar are one piece then it would be pretty hard to attach an lnbf if any usable way. in this case you would have to replace the scalar as well. i use a dmx741u lnbf with a .30 dish with no probs. im sure the scale on it goes to .20 or .22.
crackt out,.
Help Needed -- John's "Bring it Back from the Dead" C-Band Project
The 12 foot Unimesh is alive!
