Can I use a Diplexer to | SatelliteGuys.US
no...diplexer combines OTA or cable (50-890mhz) and Satellite (950-2150Mhz) into one cable
since both the KU & DBS sides of the Invacom have the same frequency range, it wont work
No, a diplexer will only work with two different frequencies, also diplexers need to be used in pairs.
You can also use a 22Khz switch or a DirecTV 4-way switch (EASY to come by) !
Diseqc Switching Problems (Twinhan VP-1020A)
Found the problem with my dish
