Can I use a *d mount KA | SatelliteGuys.US
topcats69
305
Willmar,MN
I have a KA *D (the big one) dish that I'm not using anymore could I take off the dish and use the pole and mount for FTA in West centeral MN??
Would the pole be ok for dish and moter
yes it will work fine. The motor can usually take amst from 1 5/8" to either 2 5/8" or 3" depending on the motor :)
I have used a StarChoice dish (2 3/8" mast) for a motor
Hd Fta?
is this a good starter system
