Can I in Minnesota get T12 sat? | SatelliteGuys.US
adwan001
55
St. Paul, MN
I am wondering if anyone in Minnesota can get T12 satellite. It's at 15 degrees west. It's listed in my Fortec Star and I tried to turn to it using USALS but it said it's out of range. I remember once looking at the footprints of the satellite and it showed that it covers parts of eastern MN.
Lyngsat website doesn't show my coordinates (93W , 40 N) as below the horizon. Here is the link: http://www.lyngsat.com/tracker/t12.html
Thanks for your feedback.
It will be quite low on the horizon.. I am not sure of the minimum size requirement for the americas feeds that far on the edge...
I cannot find footprint data for it, I guess Eutelsat does not care much for their leased birds so they do not have ERP maps.
If it was possible, it would have to be a dedicated dish, as your motor wont go that low on the horizon either way
Sat Finder says:
Code:
Latitude 40° 0.000'N Longitude 93° 0.000'W
                         Sat Name Sat Lng Az(t) Az(m)    El  Skew
                       Telstar 12   15.0W  97.8  95.9   0.5 -49.4
You had better have a VERY clear LOS to to the East.
They dont have ERP data for that far west.. they only have NYC, Boston, and Miami, 49 and 48dB respectively, it would probably be closer to 45 or so that far west..
Code:
                         Miami, FL 33196
          Latitude 25° 39.690'N Longitude 80° 26.460'W
                       Telstar 12   15.0W 101.2 106.8 13.5 -62.2
                     Intelsat 901   18.0W 102.7 108.4 16.3 -61.5
                     Intelsat 603   20.0W 103.8 109.4 18.1 -61.1
                            NSS 7   22.0W 104.9 110.5 20.0 -60.6
                     Intelsat 905   24.5W 106.3 111.9 22.3 -59.9
                     Intelsat 907   27.5W 108.1 113.7 25.0 -59.0
                   Hispasat 1C/1D   30.0W 109.7 115.3 27.3 -58.1
                     Intelsat 801   31.5W 110.7 116.3 28.7 -57.5
                     Intelsat 903   34.5W 112.7 118.4 31.4 -56.2
              AMC 12 & Telstar 11   37.5W 115.0 120.6 34.1 -54.8
                          NSS 806   40.5W 117.3 123.0 36.8 -53.2
                        PAS 6B/3R   43.0W 119.5 125.1 38.9 -51.7
                           PAS 1R   45.0W 121.3 126.9 40.7 -50.4
                     Intelsat 705   50.0W 126.4 132.0 44.8 -46.5
                     Intelsat 707   53.0W 129.8 135.4 47.2 -43.8
                     Intelsat 805   55.5W 133.0 138.6 49.1 -41.3
                            PAS 9   58.0W 136.4 142.0 51.0 -38.5
                         Amazonas   61.0W 140.8 146.4 53.0 -34.7
           EchoStar 3 & Rainbow 1   61.5W 141.6 147.2 53.3 -34.0
                 Estrela do Sul 1   63.0W 144.0 149.7 54.2 -32.0
                     Brasilsat B2   65.0W 147.5 153.1 55.4 -29.0
                     Brasilsat B1   70.0W 156.9 162.6 57.8 -20.7
                 Nahuel 1 & AMC 6   72.0W 161.1 166.7 58.5 -17.0
                        DirecTV 5   72.5W 162.1 167.8 58.7 -16.0
                            SBS 6   74.0W 165.4 171.0 59.1 -13.1
                            AMC 5   79.0W 176.7 182.3 60.0  -3.0
                          Nimiq 2   82.0W 183.6 189.2 60.0   3.2
                            AMC 9   83.0W 185.9 191.5 59.9   5.3
                     Brasilsat B3   84.0W 188.2 193.8 59.7   7.4
                           AMC 16   85.0W 190.4 196.1 59.6   9.4
                            AMC 3   87.0W 194.9 200.5 59.1  13.4
              Intelsat Americas 8   89.0W 199.2 204.8 58.5  17.2
                 Galaxy 11/Nimiq1   91.0W 203.3 208.9 57.8  20.9
                     Brasilsat B4   92.0W 205.3 210.9 57.3  22.6
                        Telstar 6   93.0W 207.2 212.8 56.9  24.4
                        Galaxy 3C   95.0W 211.0 216.6 55.9  27.6
              Intelsat Americas 5   97.0W 214.5 220.1 54.8  30.7
                        Galaxy 4R   99.0W 217.8 223.4 53.5  33.5
                            AMC 4  101.0W 220.9 226.5 52.2  36.2
                            AMC 1  103.0W 223.8 229.4 50.9  38.6
                           AMC 15  105.0W 226.5 232.2 49.4  40.9
                          Anik F1  107.3W 229.5 235.1 47.7  43.2
         DirecTV 6 & EchoStar 6/8  110.0W 232.6 238.3 45.6  45.8
                          Anik F2  111.1W 233.9 239.5 44.7  46.7
                    Solidaridad 2  113.0W 235.9 241.5 43.1  48.2
                         SatMex 5  116.8W 239.5 245.2 39.9  51.0
          EchoStar 7 & DirecTV 7S  119.0W 241.5 247.1 38.0  52.4
  EchoStar 9/Intelsat Americas 13  121.0W 243.2 248.8 36.2  53.5
                       Galaxy 10R  123.0W 244.8 250.4 34.4  54.6
                        Galaxy 12  125.0W 246.3 251.9 32.6  55.6
             Galaxy 13/Horizons 1  127.0W 247.7 253.3 30.8  56.5
 Intelsat Americas 7 & EchoStar 5  129.0W 249.1 254.7 29.0  57.3
                           AMC 11  131.0W 250.4 256.0 27.2  58.1
                        Galaxy 1R  133.0W 251.7 257.3 25.4  58.8
                           AMC 10  135.0W 252.9 258.5 23.5  59.5
                            AMC 7  137.0W 254.0 259.7 21.7  60.1
                            AMC 8  139.0W 255.2 260.8 19.9  60.6
                     EchoStar 1/2  148.0W 259.9 265.5 11.6  62.5
        Satellite Finder is (c) Copyright 2004, P. Lutus
Thanks to you all for the insightful comments. I guess it may not be worth the hassle of dedicating a 1.2 m dish for it. Also my east is blocked by big trees even if I put the dish on the top of the house.
Conclusion: forgetaboutit :)
Those in the eastern U.S. have no trouble seeing T12 with a 76cm dish (I think). :)
Where I live, in northern Minnesota, the elevation is almost precisely 0°. If you live very close to the WI-MN border, you may be able to get it if you mount it very high where there are no obstructions to the direct west. Otherwise, I would first consider moving to Michigan :(
T12 used to carry Israeli Channel 2. But recently I looked on lyngsat.com and channel 2 is not lised under T12 anymore.
KBS America
aiming trouble on amc 4
