Can I get Sky Angel with a Voom dish? | SatelliteGuys.US
stevet96
40
My wife and I really would like to get Sky Angel. We currently have Voom as our provider. Voom's satellite is sitting at 61.5, the same as Sky Angel. Would I be able to use the Voom dish to get both Sky Angel and Voom? Would I just need to hook up a Dish receiver and/or add a Dish switch?
thanks,
Steve
yes Steve
You should be able to use both on the same dish. I know people have Dish & Vopom off 61.5 :)
The LNB up on the dish needs to have 2 outputs. Run a line from the dish to the Dish/Sky Angel receiver and call them up :)
My neighbor does the same thing. One line from the Voom dual LNB to the Voom receiver and the second line to the Dish receiver. No problem at all.
See ya
Tony
Thanks for the quick responses. Now I just need to find a cheap dish receiver ...
What Channel Is Replacing INSP 9718???
"TV guide"?
