Can I Dim front panel light VIP612? | SatelliteGuys.US
david_jr
2,723
1,026
Hancock, MA - The Berkshires
Is there a way to dim the front panel light on a VIP612? I like to go to sleep with music playing, but the panel lights up the room with the lights off. Any help appreciated, I tried searching.
I would use something like this.
Amazon.com: Map Dot Stickers - 1/4" Diameter - Black: Office Products
Or something less opaque if you just want to dim it.
I had a customer who complained that their dial up modem was too loud. I took a look and couldn't find anyway to lower the volume on the modem. ( It had an onboard Piezo speaker. ) So I eventually stuck two layers of electrical tape over the speaker hole. It lowered the volume about 75%.:D
That was audio, but same idea. :) I would think that masking might show some glow and something like electrical would block it completely. The little dots above would have a nicer appearance. I would go up to Wal-mart and look in the stationery aisle.
NEW Dish Network Dish WESTERN ARC 1000.4 TURBO HD on eBay
ViP 722: Error 850 with new Toshiba 1 TB EHD
