Can I delete or change the Accuweather pinned to this forum? | SatelliteGuys.US
dwarren2
4,076
287
Rochester, NY Region
Someone pinned the Accuweather for Ann Arbor to this forum. Is it possible to delete it or change to my locl weather when I'm on theDish Forum?
Click on it and change it to the area you are in. :)
It picks your location based on your IP address, but in some cases the IP info is wrong or you are using a satellite provider.
Reactions: gadgtfreek
Mine came up as Glendale Az, only off by about 50 miles so I accepted it. Is it picking up location based on Server?
based on the IP address you are using.
I dont know what database they are using but if I look at your IP our database shows your IP in Mesa, Az.
Interesting. I am in Mesa so that makes sense. Sounds like a fun experiment to mess around with some day Scott.
If changing the location does not stick you likely have 3rd party cookies disabled. Enable that and you can change the location. You may be able to disable third party cookies again once the cookie is set.
Question on Hopper replacement with Joey that works fine
Possibilty or pipedream?
