Can I add another receiver? | SatelliteGuys.US
cruzmisl
114
Hi All,
I have a 622, 625 and a 211. All are only hooked up to single TV's but I want to upgrade the 622 to a 722 and move the 622 to my bar. Will they allow me to do that? Is there a maximum number of receivers one can add to an account? All the TV's I have are HD and I hate SD signal on HDTV's.
Thanks,
Joe
As long as we're on the subject, can you add more than two receivers in a house with just the one dish or do you need to add another dish?
You can trunk up to 3 DP34s or DPP44s together for a maximum of 12 receivers off one dish. Not sure if you could go above that with a quad...
Edit: According to this post, a DP quad can feed two chains of switches. So, you should be able to support 24 receivers from trunked switches from one dish. ;) That's 48 independent tuners in the case of 3 trunked DP44s on each chain.
Turbo HD package subscribers...there may be hope!!!
DVR Events (NBA games) not being recorded
