Can dishes be painted? | SatelliteGuys.US
bloomdog
306
I would like to paint my dishes. WIll this interfere with reception at all? Are some paints better than others?:confused:
Believe that its ok....but you must use non-metallic paint.
Someone should chime in with more info.
Otherwise, did you search the forum yet? I've seen this subject in the past.
Do a search for painting.
That's been asked for Dish, DirecTV, and FTA users a number of times.
Should find many informative posts.
Generally, you -can- paint the dish and it won't be a problem, but take a look through the forum for more info.
I want to design vinyl stickers to customize my dish(es). Like favorite pro team, etc....
Getting circular sigs
Pansat 2700 setup
