Camper Hookup | SatelliteGuys.US
Camper Hookup
Abeo
Iowa
Okay, heres the equipment we have:
5 Lnb Slimline Directv sat
HR-21 Receiver
B Bands
Zinwell ms6x8wbz
I am attempting to hook everything up but am getting no signal at all. All 0s. I have 4 lines off the dish to the Zinwell switch, then output to band from the Zinwell switch to bbands, then bbands to the hr21 receiver and I still have nothing. Dish alignment is correct. I can't find a diagram or answer to save my life. Need help badly! Can anyone help me get this setup done?!?! Thanks!!!
Abeo
Why are you using a Multi Switch if you only have one recvr ? It's not needed.
Are you sure that your signal strength is correct ?
If so, you should have picture.
newbie question
DirecTV2PC Oh My!
